Using an unlocked phone
Does anyone know if a Cubot GT95 android can be used on the koodo network?
Photo of Missy
Posted 3 years ago
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Missy,
If the phone is compatible with Koodos network then sure it will granted it's unlocked. If you have the IMEI number of the phone you can use Koodos phone compatibility tool to double check (link provided below):
If you don't have that information handy, then you can check the specifications of the device so you'll know whether or not it will work on Koodos network. They use the following frequencies:
HSPA/WCDMA - 850/1900
And LTE - 1700/2100
Hope that helps :)
