Use Koodo prepaid SIM in Mexico for incoming calls from Canada only
  • Updated 10 months ago
I will be in Mexico for 2 months. I will be using a Mexican SIM card in my unlocked phone, but I would like to bring a second unlocked phone with my Koodo SIM, only for incoming calls. This is because I may receive the very occasional call from Canada on this number. Is there a way to do this without paying the $40 per month roaming? I don't care about the rate per minute because I may not receive ANY calls at all and if I do, I will call them back on Skype.
Photo of susan
susan
  • 268 Points 250 badge 2x thumb
Posted 10 months ago
Photo of Robert
Robert, Mobile Master
  • 107,614 Points 100k badge 2x thumb
Hello Susan,
You can just bring your phone and not answer the calls. You don't need to have the roaming add-on in order to do this!!  Your phone will work normally without an add-on as well (as long as you have the free roaming add-ons)
Photo of David
David, Mobile Master
  • 93,798 Points 50k badge 2x thumb
It is not possible to Roam in Mexico on a prepaid Koodo SIM. On a post-paid SIM you could accept a call at the pay-per-use rate of $1.50 per minute.
Photo of susan
susan
I am confused. Don't David's response and Robert's response contradict each other?
Photo of Robert
Well, we must know if you're on prepaid or postpaid? Because if you're on prepaid, then David's answer is the good one. Roaming on prepaid is limited to the US so if you go to Mexico with a prepaid SIM it won't connect to the network.
PS : I missed the detail that you might be on prepaid.
Photo of susan
susan
I mentioned in the title of the post that I am on prepaid.
Photo of Goran
Goran, Mobile Master
  • 97,688 Points 50k badge 2x thumb
You can use Fongo or Text now or anything else that gives a Canadian number and receive calls that way.
Photo of susan
susan
Goran, could I ask you to explain how this works?
Photo of Robert
Here's the answer yo your question : https://www.fongo.com/how-it-works/
If you have something you don'T understand, please come back and ask it!
