USA Incoming Call to landline then call forward to my cell
  • Updated 1 year ago
I currently has unlimited Canada Wide talk plan.  Want to Call Forward my office landline to my cell.  If the incoming call is originated from USA, will that be consider US long distance call or Canada call because my office phone is a Canada number?
Thank you,
Photo of KoodoNew99
  • 150 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Daniel Hryb
Daniel Hryb
  • 3,630 Points 3k badge 2x thumb
it will be treated as a normal incoming call. Where the call originates does not make a difference in receiving on your cell phone.  Depending on how your plan treats incoming calls will determine how you are billed.
Photo of BobTheElectrician
  • 57,086 Points 50k badge 2x thumb
All incoming calls are treated equally regardless of origin as long as you are physically located in Canada. There is no long-distance surcharge, and the incoming call will display the originating number on your screen as it rings thru.
