US roaming block for customeres in boader towns.
  • 3
  • Idea
  • Updated 6 years ago
  • Implemented
not just for texting
but for calls and data
so many instances where people are getting charged for roaming in canada
because thety live in a boader town
usally told to manually select networks, but this is annoying as you maybe on a call and you don't know if your roaming or not, and who thinks to look down at thier phone in a middle of a call to make sure they arent roaming.
so please koodo, can u get a uUS roaming block not just for sms but for everything :)
there will be less disputes for accidental roamaing ;)
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
Posted 6 years ago
  • 3
Photo of Erwin
Erwin
  • 23,576 Points 20k badge 2x thumb
yes please
Photo of John Burke
John Burke, Mobile Master
I believe this currently works for pre-paid (since pre-paid aren't able to go to the US) ... so theoretically it seems like it's something doable, though other carriers work the same way.
So while I agree it would be good to have, I'm not sure they can unless you're using a non-Smartphone.
HippieLongstocking
i was told telus does it .but its hard to say
Photo of Daniel AJ
Daniel AJ
  • 4,364 Points 4k badge 2x thumb
Set your phone to Manular network selection. This is not something you do per call, this is a general option in any good phone. The phone will then only connect to the network you have chosen manually.
HippieLongstocking
im aware of that
but sometimes doesnt always work.
Photo of Daniel AJ
Daniel AJ
Haha, that should have read "manual". But "Manular" is a nice creation, too. :-)
Photo of Derek
Derek
  • 560 Points 500 badge 2x thumb
this always happens when i'm visiting girlfriends parents, literally other side of the river is the US, i get the txt msgs when i get on AT&T's towers, but if my phone rang, i probably wouldn't see it before i answered :(
