US voice roaming
I only want to add on US roaming for voice for 1 week. No text. Is there an option for this? And if so, what is the fee and how many minutes does it include?
Photo of Meri Dai Edwards
Meri Dai Edwards
  • 126 Points 100 badge 2x thumb
Photo of Daniel Kim
Daniel Kim, Mobile Master
here are the roaming add ons http://help.koodomobile.com/Portals/0...
It sounds like you'll want the 10 day add on. Text comes bundled with it. Or if you're only going to make a few calls, you could just go with the Pay-per-use rates which is $1.50/month.
Meri Dai Edwards
If I recall, when I traveled to the US last year I could select voice roaming only. Is this not an option anymore?
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Meri,
Daniel is right when it comes to getting the new roaming add ons as they can be cheaper than using a pay per use feature, but the feature that you're referring to is still able to be added as a $0 option but just keep in mind that the rates have changed and are explained in the link that was provided. I've provided another link so you can have an idea of what your options are and how to go about adding the feature if you choose to go that route.
http://help.koodomobile.com/coverage-...
Hope this helps :)
