US roaming not working.
  • Updated 11 months ago
I texted 10ALL on Aug 6 and received confirmation but data does not work. I can't tell if phone works or if I am paying by minute. I've turned phone off and on and checked all settings. Any suggestions on how to fix?
Photo of Bruce MacLeod
Bruce MacLeod
  • 90 Points 75 badge 2x thumb
Posted 11 months ago
Photo of Allan
Allan, Mobile Master
  • 62,562 Points 50k badge 2x thumb
Is data and data roaming both turned on? Is everything else working, just not data?
Photo of BobTheElectrician
BobTheElectrician
  • 67,528 Points 50k badge 2x thumb
Photo of Robert
Robert, Mobile Master
  • 107,160 Points 100k badge 2x thumb
Hello Bruce,
If you log in into self-serve do you see extra charges? If you do then the roaming package doesn't work...
Bruce MacLeod
Texting and calls are working but they would anyway whether I added the service or not, just at the per transaction/call rates.
I checked and the transaction history shows the service being activated. Data is turned on in the phone. It's just not working. Not sure what the issue is. There are enough hotspots around so I expect I'll be ok. Troubling though should I have really needed access.
Thanks for taking the time to respond and make suggestions.
Photo of Robert
Do you have data ROAMING turned on?
Bruce MacLeod
Now that's a good question. I wasn't aware of such an option. I found it and turned it on which should solve the problem. Many thanks!
Photo of Robert
No problem. You're the second one I help today who had the same problem.
