us roaming drains battery
  • Updated 2 years ago
I have a new to me iphone 5 and I travel to the US a lot. I've noticed that in Canada my phone is perfect but in the US the battery drains super fast. It will go from 100% to dead in 4-5 hours. In Canada it lasts 2-3 days. I often see it display 'no service' in the US and am wondering if maybe it is constantly searching for Canadian towers? It is locked to the telus/koodo network, my last phone did not have this problem and was unlocked, could the lock be the issue?
Photo of Joe
Joe
  • 170 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 91,316 Points 50k badge 2x thumb
Being locked is not the issue. It will select a roaming partner network to connect to automatically and that's that. I would say that you are in a locations where the roaming partner has a very poor network, and the phone is using a lot more energy in order to maintain the connection. Last time you were likely in another area I presume where the signal strength was much better.
Photo of Joe
Joe
So after the reset and about 1.5 hours it's down to 75% with zero use. Can you tell me about the other option- go to manual?
Photo of Goran
Settings; Carrier; Automatica Network Selection OFF; wait 1-2 minutes for the list to populate. See if there are multiple T-Mobile options and try the 3g/WCDMA for a period and then the LTE/4G one and see if either are better.
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
Hey Joe! Did Goran`s suggestion help? Keep us posted!
Photo of Joe
Joe
I tried turning the carrier settings off automatic in Raleigh, Nashville and Washington DC. It didn't seem to do anything until just now after re-reading Goran's post, you're right it does take literally 1-2 minutes. I just selected T-mobile, it seems to have the strongest coverage. I'll give it an hour and see how my battery is doing #feelingoptimistic :)
Photo of Joe
Joe
Ok, I am very happy to report that this seems to be the fix I've been looking for! My phone has been on all night here in Detroit and it still has lots of battery. Thank you so much Goran!
