US Roaming add-on timeout?
  • Updated 2 years ago
I will be leaving for the US on Monday and returning on Thursday. If I activate a 3 day Roaming add-on on the Monday, will it expire at 11:59pm on the Wednesday or on the Thursday?
It says online that it will expire 3 days after you added it, but I'm not sure if this 3 days includes the day you activate or not.
Thanks in advance!
Photo of Chelsea Marina
Chelsea Marina
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 90,654 Points 50k badge 2x thumb
"Add-ons are activated when you complete the purchase and are good until 11:59pm on the day they expire. For example, if you bought a three-day add-on on July 1, the add-on would expire on July 4 at 11:59pm."
http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling
So you get 3 full days plus whatever part of the day you added it then.
Also keep in mind that you are allowed one type of add-on per billing cycle. So you could do a 3 day once, but add in a 10 day or whatever if you wanted/needed but not another 3 day immediately unless the billing cycle has restarted.
Photo of grampad
grampad
  • 1,876 Points 1k badge 2x thumb
Here is a copy of the text I received from Koodo when I activated 3tnt at 1055 AM Aug 16
"Koodo: Your roaming add-on is now active. It will expire on 2016-08-20 at 12:01am, Mountain Standard Time."
So, it's almost like getting 3.5 days but beware of the end time as what 12:01am really means is midnight and 1 second not 1 minute. By the way apart from the occasional speed issue with texting and connecting the call it was flawless.
Photo of Falcon
Falcon
  • 452 Points 250 badge 2x thumb
You can add on with a text message the day you start travelling.  The above link takes you to a webpage explaining how it works.
