US Roaming Add On Question
Two questions about getting an US roaming add on to my current plan.
1. If my current plan does not include data but I get an 3All add on with data included. Do I still pay extra in addition to the add on for the data used?
2. If I come back to Canada before the add on expires, can I use the remaining data quota in Canada with no additional charges?
Thanks.
Photo of Wen
Wen
Photo of Nabil
Nabil, Employee
  • 6,866 Points 5k badge 2x thumb
Hi Wen,
1. It does not matter if your current plan has data included. Just make sure you do not have the data block on your account.
2. If you add the US Roaming Combo - 3 day (3ALL), you'll have unlimited talk and text, and 100MB of data while travelling within continental U.S., Hawaii , Alaska, U.S. Virgin Islands, and Puerto Rico for 3 days. Back in Canada, you won't be able to use the remaining of your 100MB of data.
Hope this helps :-).
Thanks
________________________
