US Roaming add on not working
I have an iPhone 5 and purchased an add on for use while in the US and it is not working.
I have tried resetting my network connections and this does not resolve the issue.
Under the cellular data tab the only completed field is APN which reads sp.koodo.com, all the user name as password fields are blank,
Photo of LTyler
LTyler
  • Frustrated that I can't use my phone
Posted 3 years ago
Photo of Dennis
Dennis, Mobile Master
  • 187,350 Points 100k badge 2x thumb
How many bars of signal do you have?
Does it say which network you are connected to?
Photo of LTyler
LTyler
3 bars (balls) and T-Mobile
Photo of Dennis
Does text or calls work?
Is it just a data issue?
Photo of LTyler
LTyler
Nothing was working.
I ended up speaking to a Koodo agent (actually 3 of them), we finally diagnosed there was a software update for my iPhone, once I installed that and turned the 'Automatic' feature under Carrier in Settings everything worked.
Thanks for your help Dennis.
