US long distance call warning
  • 2
  • Updated 3 weeks ago
I get a long distance call warning when I call within Canada even my plan covers calls across Canada, but when I call US, there is no warning message, can I set up a warning message for US call ?
Photo of ml
ml
  • 210 Points 100 badge 2x thumb
Posted 3 weeks ago
  • 2
Photo of Goran
Goran, Mobile Master
  • 90,296 Points 50k badge 2x thumb
I don't believe that you can set one up for that. The idea is that you there's local or long distance calls in Canada and you might have a plan without unlimited nationwide minutes whereas calling out of country will always cost extra.
Photo of BobTheElectrician
BobTheElectrician
  • 61,676 Points 50k badge 2x thumb
Check out a call blocker on Google Play such as Mr. Number, though most of them are primarily meant to filter incoming calls.
Photo of ml
ml
My plan covers unlimited Canada wide call, but not US calls, what I need is a long distance charge warning for US calls, not Canada calls. Can Koodo do it?
Photo of Goran
  • 88,928 Points 50k badge 2x thumb
I'm sure that they could, but likely won't, because it's implied that you will pay extra to call a non-Canadian number.
May I ask why you feel that you need  warning for US calls?
Photo of Dennis
Dennis, Mobile Master
  • 185,756 Points 100k badge 2x thumb
Try dialing with and without a 1 in front and that may change the warning
Photo of Dinh
Dinh, Mobile Master
  • 32,640 Points 20k badge 2x thumb
@ml:
Technically, Koodo could, but they didn't implement it. Only  international calling (to other countries besides US) could be blocked. Most postpaid plans from other carries were similar so I guess it was the norm.
I would just be careful when choosing a number to dial when calling out. Unlimited Canada-wide calling doesn't entitle people to call anyone. If you are afraid of the accidental US calling charge, you could buy the add-on international long-distance saver ($3) to reduce the charge. However, I don't think you need it.
I don't like using 3rd parties app for calling, normally they use more battery than the native dial app.
Photo of TJ Smith
TJ Smith
  • 4,360 Points 4k badge 2x thumb
Dennis hits it out of the ball park.
I'm sure whenever you're dialing a canadian number you don't put the "1" at the beginnig. The automatic system tells you :"Log distance charges may applied".
But when you're calling the US you always dial the "1" before the 10 digits number so the system bypass the warning message.
