US adds-on for self serve
  • Updated 1 year ago
Hi, I'm in prepaid account and I add adds-on for US text et al. Right now I'm in US but it doesn't work. My iphone can't find signal at all. If someone can help me out, there'll be great. Thanks!!!
Photo of Jenson
Jenson
Posted 1 year ago
Photo of David
David, Mobile Master
  • 93,840 Points 50k badge 2x thumb
Try going to Settings > Carrier, and turn off Automatic. Select from the list which populates. AT&T is usually a good choice, but you can choose which ever gives the best signal. Remember you may have to change this as you travel, and will definitely need to do so on your return to Canada.
Restart your phone.
Photo of Jenson
Jenson
Thanks David. I try this method today, however, it is still showing"searching" and none is shown up. Do you have any other suggestion?
Photo of David
  • 93,388 Points 50k badge 2x thumb
Where are you in the US? There are some locations with poor or non-existent coverage.
Photo of Jenson
Jenson
Washington DC
Photo of David
At this point, I suggest a quick Private Message to Koodo from their Facebook page, and they can see what's happening for your account.
