Upgrading Tabs
If I have a existing tab before the new tabs came out, can I upgrade to tab L even though I still have some remaining tab balance to pay off or do I have to pay off the tab balance to upgrade?
Photo of Anjelica Lacoff
Anjelica Lacoff
Photo of Myke
Myke
If my information is correct & I'm understanding it correctly, when upgrading to a higher Tab, the previous tab balance must be paid first(either billed out or paid via CC).
I'm not 100% as I'm still foggy on it.
Photo of Dennis
Dennis, Mobile Master
  • 187,648 Points 100k badge 2x thumb
When upgrading Tabs you have to be upgrading your phone. At this time you must pay off your existing tab balance.
At the end if the day, you are paying the same amount since if you did notpay off your tab you would have had less tab room by that same amount.
Note that if you want a Tab L, you wll require a Tab L Plan
Photo of Myke
Myke
While true, you can still upgrade your phone without changing your tab size. That doesn't require paying out the tab.
Photo of John Lee
John Lee
Of course. You can upgrade your phone without changing your tab size but that means the amount of money you are paying for your phone may either be less or more depending on your current tab size.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
As well as requiring a tab L plan to be eligible you will then have a recurring charge of $10 per month added ontop of tour plan each month for the next 2 years or until the tab is paid in full whichever is sooner.
