Upgraded phone and plan changed. Did not want plan to change
  • Updated 2 years ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: positive tab mentions
Hi, I just upgraded to a new phone and my plan changed. I did not want this to happen as I was very happy with my plan. How do I get this fixed back to what it was?
Photo of Andrew Power
Andrew Power
  • 114 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Jonathan I
Jonathan I, Mobile Master
How did you purchase this phone? Was it through the website or at a store? Did you use Tab Large? You shouldn't have had to change your plan unless it was suggested you do (and only if it worked out to be a better deal) or you took Tab L.
Andrew Power
Purchased in store. Tab is $15(13 after my positive tab was factored in). Changing the plan was not discussed.
Thanks
Photo of Mayumi
Mayumi, Mobile Master
  • 115,182 Points 100k badge 2x thumb
What plan you had before and what plan do you have now?
Photo of Goran
Goran, Mobile Master
  • 97,682 Points 50k badge 2x thumb
I believe now tab medium also requires that you have a plan at least 40 dollars, so if you had a plan less than 40 before that could be why but you were absolutely still supposed to have been told and asked about it in order to make an informed decision and consent to go ahead with it.
Andrew Power
Thanks!
Photo of Julie
Julie, Official Rep
  • 2,344 Points 2k badge 2x thumb
New customers would indeed have to choose from one of our Tab M plans, however, existing customers have the choice to keep their GF plan even if it is <$40.
Andrew Power
Had $40 for 500 minutes and 1gb data. Now only have 500mb and the auto loading of the programs chewed up that before I could get home.
Photo of Mayumi
So, you didn't use Tab Large to upgrade your phone.
It's a same $40 plan, but you had a previous promo plan with 1 GB.
Upgrade your phone with Tab M shouldn't have to change your $40(1GB) plan.
I would call Koodo tomorrow and explain your situation and ask your plan back.
*611 from your Koodo phone, option 5 > then press 0
Andrew Power
Thanks. Will try to call in the morning. Appreciate the help.
Photo of Julie
Julie, Official Rep
Hey Andrew!
It seems like your plan was changed back to your previous plan with 1 GB. Hope everything is sorted it out now :)
