Phone doesn't ring, call forwarded to Koodo's voicemail
  • 3
  • (Edited)
Sometimes (once or twice a day) my phone (Samsung Galaxy S3) doesn't ring when someone call me but (at the same time) my phone's signal is full. My call will be forwarded to Koodo's Voicemail. Why?! What should I do?
And also my sister has this problem (Samsung Ace).
Photo of PA
PA
  • 90 Points 75 badge 2x thumb
  • sad
  • 3
Photo of Chantel Sharpe
Chantel Sharpe
Sometimes you can lose signal and get it back very fast, it could be that the call
Came through when signal was lost. If it does keep doing it though maybe try a phone reset and see what happens, if that doesn't work I would contact Koodo for further help.
Photo of PD
PD
  • 6,798 Points 5k badge 2x thumb
If your phone is not busy and has full signal, it should not do this. If you see this behaviour consistently report to koodo tech support.
Photo of Myke
Myke
It doesn't hurt to do a battery pull once a day. This helps keep the network connection fresh. Some may see this a big inconvenience , but it's just taking the battery out(with the cell phone on), waiting 1 minute, putting it back in and turning it on. It's like restarting a computer almost.
Another thing to keep in mind is if you are inside, there may be something that is affecting the service. Koodo can't guarantee indoor service. If you don't have any issues when you're outside, this may be the cause.
If you find that you can't receive calls no matter where you are, give Tech Support a call (*611 option 6) as it may be network related.
Photo of Doreen Dugas
Doreen Dugas
  • 64 Points
Problem with one landline phone in just one room at an airport...What could be the cause from this one area and this particular phone that sends a call directly to voicemail?
