Unlocking phone, activating on existing plan??
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: Unlocks are now free
I've received conflicting advice from the customer rep from a Koodo outlet and then a customer rep via the phone. Quite irritating considering the attitude of the customer rep in-store (A condescending, ill-informed brat at the Dufferin Mall location) but that experience was redeemed by the courtesy of the customer rep via the phone.
I just want to confirm the procedure for unlocking a non-koodo phone and then activating it on my existing phone plan:
1) Unlock the non-koodo phone with its current provider or online (Any recommendations for online unlocking services?)
2) Buy a new micro/nano SIM card if needed for the new phone (Current phone is changing from Samsung Galaxy Ace to an iPhone 4, so I am guessing a new SIM will be needed?)
3) Head to self serve --> Mobile Phone --> Swap phone. Enter in phone details to activate the phone for use on the existing plan. (Are there any additional fees that I should be aware of as a result of swapping phones?)
Is this procedure correct? Could someone confirm please?
Thanks very much!
Sincerely,
Tired of commuting around the city just to be misinformed
Photo of Michelle Tran
Michelle Tran
  • 72 Points
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 103,888 Points 100k badge 2x thumb
-> Yes it is correct. I've been looking on ebay for unlock codes. But it depends on the phone you have.
iPhone = go with provider because cheepest way. You will not find something cheaper then 35$ for an iPhone unlock.
->Yes, new SIM from Koodo will be needed unless you cut it. What you need is a MICRO-SIM
-> Yes, this is correct. No additional fees
Photo of Khaleila
Khaleila
  • 4,102 Points 4k badge 2x thumb
Hey Michelle,
Thanks for reaching out. The answers provided by Robert and Joshua Su are correct. I am glad that the rep over the phone was able to restore back your faith :). However, as for the rep at the store, this type of behavior is not accepted and we'd like to take a look into this. Would you mind sending us an email to: http://koo.do/YqucV0, please include the date, time,name of person (if you have it) and location once again. Thank you.
________________________
