unlocking info
  • Updated 1 year ago
Hello , is there any way i can unlock my phone online without calling koodo using self serve?
Photo of Bilal Malik
Bilal Malik
Posted 1 year ago
Photo of David
David, Mobile Master
  • 83,260 Points 50k badge 2x thumb
Yes, there are third-party unlocking companies which will unlock your iPhone for 2 to 3 times the price Koodo will charge you.  You may be able to start the process with a PM to Koodo from their Facebook page, but your best option would be a call first thing in the morning to speak to a CSR.
Photo of Lloyd Willett
Lloyd Willett
  • 2,258 Points 2k badge 2x thumb
How much does koodo charge to unlock a android phone and then how much from third party like eBay thanks
Photo of Robert
Robert, Mobile Master
  • 100,836 Points 100k badge 2x thumb
Koodo will charge 50$. On eBay, depending on the phone, it will be around 5-15$
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 136,982 Points 100k badge 2x thumb
Only for Android. iPhones will typically cost $100-$150 for a third party unlock.
Photo of mmazurlaptop
  • 60 Points
For a Galaxy S5 I used unlock Canada. For the one S5 had no problem for the second had an issue but within an hour support helped me sort it out. You can search for them on google or you can use my link code. $20.00 for code. Good luck took less then 12 hrs to receive the code. Unlock Canada: http://unlockcanada.com/?raf=ref4761679
