unlocked Verizon Galaxy 3 will it work with a koodo sim card in it in Canada
It is a sch1535 will it work with a koodo sim card in canada will voice text and data worked and will the data be less than 3g
Photo of Terry Romanchuk
Terry Romanchuk
Photo of Rocky Balboa
Rocky Balboa
http://koodomobile.com/en/on/switch2k... click this link and input your IMEI # into that tool. That'll tell you your answer! give it a star of this answers your question
Photo of Humberto Giambrone
Humberto Giambrone
  • 4,900 Points 4k badge 2x thumb
Isn't Verizon CDMA? I'm not sure that can that be used with Koodo, or it's at least very complicated. Hopefully somebody more in the know can chime in on this.
Also, TELUS going to start killing it's CDMA network, so if this is to be a long-term phone, it might not have too many years of use even if you could get it working.
Rocky Balboa
I know it's HSPA for sure! I just don't know if it's CDMA.....
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,100 Points 100k badge 2x thumb
No it will Not work it is strictly a CDMA device that was specifically built for verizon
Humberto Giambrone
I thought I read on these forums in the past that unlocked CDMA devices could work, but it's complicated. From what I understood, the hard part is the unlocking, but once that's done, there is a way. I could look it up, but too busy right now.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,436 Points 100k badge 2x thumb
Koodo's systems will not allow a non-koodo MEID to be registered to a Koodo account.
