Unlocked Rugby LTE decided to stop working with Koodo!?!?!
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
my unlocked rugby lte has been working fine with my koodo sim card for a few weeks. Then it spontaneously stated emergency calls only. When i attempt to call it states the phone is not registered on the sim. It shows full bars at home which is normal and the sim works in other phones. My parents bell sim card works in the phone so i thought maybe it was a temp unlock code so i brought it to the mall to get it re unlocked and they cant figure it out. They say it might not but compatible under koodo but they have no idea they have never come across this problem. Will it never work with koodo again? and why? i ask again WHY?
Photo of Philip Konzelmann
Philip Konzelmann
  • frustrated
Did you check
Settings / wireless and net works / mobile network
Make sure network selection is on automatic, use 2g or use gsm only isn't selected?
Let us know
Philip Konzelmann
of course. ive been researching this problem for at least a week now.
Well I always like to cover the obvious stuff first. You never know.
Philip Konzelmann
for sure. i appreciate it..
Photo of Jonathan I
Jonathan I, Mobile Master
The phone wouldn't suddenly reject the Koodo SIM. If it was working before it will always continue to work in the future unless the phone gets damaged or something.
I would replace the SIM card and see if that fixes anything. Just yesterday my phone wasn't sending texts, but literally everything else worked. I replaced my SIM card and it started working again. Sometimes you just get a dud. They're a dime a dozen.
Philip Konzelmann
the person who is trying to fix it told me his friends koodo sim didnt work either.
Photo of Jonathan I
Hmm. Does your SIM work in a different device?
While the support is limited for non Koodo devices, I would call tech support and see what's going on. Also make sure your bills are all paid up and you haven't hit your spending cap limit (if applicable).
Philip Konzelmann
yes it does and i visited a koodo store and called. they said they couldnt help me. but they have no idea what it is.
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Philip, I recommend calling our Technical Support & having them log a network ticket. This will allow us to look further into the network to see where the issue lies. *611 Option 6.
________________________
Philip Konzelmann
ive called before and they did a whole bunch of things to try and see if the issue was in their side of things but they found out it wasnt. Should i still call about what you asked?
