Unlocked iPhone 5S and LTE?
I have an unlocked iPhone 5S and I'm trying to configure it to work on Koodo. My Koodo SIM card registers but I only see 3G network connectivity, no LTE. Is there something special I need to do to make it work?
Photo of Discover Miramichi
Discover Miramichi
Photo of Sophia
Sophia, Mobile Master
If your settings show that you have enabled LTE, you might be in an area where it is not available... otherwise it should work :)
Photo of Dennis
Dennis, Mobile Master
  • 187,648 Points 100k badge 2x thumb
Where did you get this unlocked iPhone 5s?
It might not be the right LTE model hence why your LTE is not Working
Photo of Ahmad
Ahmad
With LTE: It will not stay on 24/7 and will frequently revert to 3G and back, especially if you're in certain area's or even certain area's of a building.
Discover Miramichi
It was originally locked to Rogers. Would that be a different LTE band than Koodo?
I don't think it's a coverage issue: I have a Telus phone that gets LTE just fine right next to this one.
Photo of Ahmad
Ahmad
No, it's not a different LTE band. Read my comment above and Sophia's as well.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Make sure you have a V3 SIM Card which is LTE capable
Photo of Jonathan I
Jonathan I, Mobile Master
All Nano SIMs are V3/LTE capable from launch so that isn't an issue.
Discover Miramichi
Thanks for the replies. Paul, how would I know if it is a V3 SIM card?
Photo of Daniel Kim
Daniel Kim, Mobile Master
don't worry you have one, as jonathan said all nano sims are v3 capable and the iphone 5s uses a nano sim.
Discover Miramichi
I haven't seen the LTE symbol since placing it in the phone yesterday, though the coverage map shows the area as having 4G LTE. (Miramichi, NB)
Speed tests have shown sporadic pings (either seems to be around 100ms or 1500ms+) and speeds top out at around 3mpbs down and 0.5mpbs up. I think something is amiss.
Photo of Dennis
Settings>General>Reset>Reset Network Settings
Photo of Al Robidoux
Al Robidoux
  • 1,262 Points 1k badge 2x thumb
Not sure if this might help either, but try to connect to iTunes to see if it tries to update your carrier settings.
