Unlocked Verizon phone on Koodo?
I'm currently in Winnipeg going to be attending University. I have unlocked my old DROID RAZR M(XT907) phone, was originally for Verizon (US Carrier). It's been unlocked to use any US Carrier (CDMA and GSM), my koodo sim card fits in it. Am I allowed to use this phone instead of the one I got when I signed up for koodo?
Photo of Corton
Corton
Photo of Sophia
Sophia, Mobile Master
If it works, of course you're allowed to use it, Corton. However to my knowledge Verizon phones won't work with Canadian bands... so don't be disappointed if it doesn't. However nobody will forbid it!
Photo of Ivan
Ivan, Mobile Master
Verizon phones with a SIM slot work in Canada, providing they have the right frequency band. I've used Verizon phones in the past. They're CDMA/GSM hybrid models. The CDMA ESN is locked down to Verizon, but the GSM radio is unlocked for use outside the US.
Photo of Corton
Corton
How will I be able to tell if it's not compatible? Will everything just not work, or will certain things not work?
Thanks for such a quick reply!
Photo of Not Jeff
Not Jeff
  • 2,058 Points 2k badge 2x thumb
Corton,
If you remove the back panel and battery in your phone, or have access to its IMEI, then you can type it into the below webpage and it'll let you know!
http://help.koodomobile.com/getting-s...
Photo of Ivan
Ivan, Mobile Master
  • 96,292 Points 50k badge 2x thumb
I've had that tool return many IMEIs as unusable, yet the phone worked perfectly well.
Photo of Corton
Corton
I put it in there, but it comes up with the wrong phone model.
Photo of Not Jeff
Not Jeff
Then you probably are unable to have it work with Koodo.
There is a chance that your device might work anyways. My recommendation is to go visit your local store and have them try a SIM card out in your phone. That's a foolproof way of finding out.
Good luck!
Photo of Corton
Corton
Alright, thanks. I may go do that.
Photo of Hello
Hello
According to GSMArena, it supports 3G 850/1900 MHz, so it will work with Koodo.
Photo of Corton
Corton
I guess all I can do is just try it.
Photo of Ivan
Ivan, Mobile Master
It will work, without LTE. It has the required 3G bands. I've used 2 Verizon phones on Koodo so far (Nokia Lumia 928 and Nokia Lumia Icon).
Photo of Corton
Corton
I tried it, and it works. Thanks.
