Unlocked Lg nexus 5x and Koodo band width?
  • Updated 2 years ago
Buying an unlocked lg be us 5x from Google. They said to make sure Koodo has the correct band width that supports it. I was going to transfer my Koodo sim month to month over to the new phone. Can this be done ok?
Photo of Gregg Mcclement
Gregg Mcclement
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 90,654 Points 50k badge 2x thumb
You can use willmyphonework.net to see but if it's from t Google store in Canada it will b compatible. Well you can just pop in your Sim an you'd b on your merry way ! I assume that you won't be changing to postpaid or anything like that a well when you say just transfer your month-to-month Sim to the new phone?
Photo of Dennis
Dennis, Mobile Master
  • 187,512 Points 100k badge 2x thumb
If it is a google nexus phone then it should be fine
Gregg Mcclement
Thanks Dennis. I purchased it and will put my Koodo SIM card in. I am sure it will work. I checked that website that Goran mentioned. It said it was compatible with Koodo as well. Thanks again Dennis
