Unlimited minutes with no data
Do you have any plans with unlimited minutes but no data?
Photo of Yanic Giroux
Yanic Giroux
  • 80 Points 75 badge 2x thumb
Photo of Ahmad
Ahmad
Not at this time :( The only plan without data right now would be the $29 Talk & Text plan and that only has 100 daytime minutes, unlimited evenings and weekends and unlimited texting
Photo of Jonathan I
Jonathan I, Mobile Master
Actually, yes:
$40 for 600 mins with Unlimited E/W at 5pm
$50 Unlimited talk
Canada-wide calling, unlimited text and pic messages (international too), and Call display/voicemail are all standard.
Sounds like you want the $50 plan. Are you new to Koodo or are an existing customer? If you're new, then the plans are still provisioned so visit your nearest store tomorrow and ask them to try activating it for you. If you're an existing client, then log into Self Serve and make the change asap before it disappears!
Photo of Ahmad
Ahmad
Unless I'm mistaken, those plans were removed. Or are they just unadvertised?
Yanic Giroux
Thank you for the info guys! I will contact Koodo to see if that plan is still available
Photo of Ahmad
Ahmad
No problem! Good luck!
