Unlimited Incoming Calls Questions
I have a question about the Unlimited Incoming Calls on some of the Canada Wide plans. If you are outside your local calling area do you still get Unlimited Incoming or are there long distance charges when someone calls you?
As well, if you are on a plan with a set number of Anytime Minutes, do incoming calls received during the day use your Anytime Minutes if you have Unlimited Incoming?
Photo of raptor256
Photo of Curtules
  • 19,666 Points 10k badge 2x thumb
Canada Wide plans have unlimited Canadian long distance, so no matter where you are in Canada there will be no long distance charges for incoming calls. Also, unlimited incoming calls mean exactly that, incoming calls will not count toward your minutes, only outgoing calls.
