Unlimited text and picture messaging...NOT!!
Does anyone else have the $30 plan...unlimited text message and video and picture messaging?and 100 minutes? but you cant get your picture messages, because you have to turn your data off. But when you turn your data back on to download a picture...it still won't come through??. This is getting very frustrating...I have 2 messages I cant recieve, If I leave my data on...I get charged $7.50 every few days...from my apps that are built in on my phone...are getting updates. Please help me get this straight....
Photo of Colleen Flaherty
Colleen Flaherty
Posted 3 years ago
Photo of Daniel Kim
Daniel Kim, Mobile Master
On your phone, go to playstore>settings>Auto updates> select over wifi only.
Also depending on your phone, the answer in this link may apply to you http://community.koodomobile.com/kood...
Colleen Flaherty
thanks for the info...I did what you said...and app updates...wifi was checked off already.
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
Call koodo you have unlimited text every koodo plans
Deped on your plan if relly old you may not have unlimited text new plans do I hope this helps take care
Colleen Flaherty
I do have unlimited texts and picture messaging, but they told me I have to turn my data off so the app updates aren't using data, then when the data is off...I can't receive picture messages...
Photo of Dennis
Dennis, Mobile Master
  • 187,452 Points 100k badge 2x thumb
Photo of Dennis
Also if you turn on data while connected to a wifi source (wifi does not even ned an internet connection) no data would be used while you download your picture messages
Colleen Flaherty
I can't receive the pictures if the wifi is on
Photo of Dennis
Wifi on while Data is on.
This way Data leakage wont occur. But the Data pipeline will be open to allow MMS downloads
