UNLIMITED MMS?????in general and S5 neo in particular
  • Updated 2 years ago
My plan says unlimited mms texts which implies no additional charges for them as they are included in the plan. Reality is after several searches and questions asked is that one must turn data on to send or receive mms at a minimum $5 cost for the first one of the month OR block all "other" data except mms at a cost of $2 a month. Why does it cost TO NOT GET something?
If unlimited mms texts are advertised as included one should be able to send / receive them just like normal texts without having to hope no "extra" data is used and with out a sender having to first text you to turn your data on so they can send you a mms.
There is a way if Koodo wanted to do it to configure their system/phones to allow mms texts without additional costs.  The phones should be configured when delivered/set up to only allow mms data without turning data on, problem solved and Koodo is once again an honest company.  It goes without saying that pay-per-use data users should be able to access "other" data when they wish by using just their phone with no additional cost to turn data on or off.
PS If there is a way to configure a S5 neo so one can use the mms feature as advertised ie no additional cost please do share .
Photo of Zana Nesbitt
Zana Nesbitt
  • 370 Points 250 badge 2x thumb
Posted 2 years ago
Connect to wifi, turn data on, send message, turn data off, disconnect from wifi
Or
Spend the two dollars and get a block. However I do agree with you that the block should be free.
Photo of DJ
DJ
  • 792 Points 500 badge 2x thumb
I have had unlimited mms for years. No extra charges. It is a part of my plan.
Zana Nesbitt
Thanks for the reply but mms texts do not work over wifi.
Zana Nesbitt
DJ, it is part of my plan as well but I only have 250 kb a cycle.   I would assume your plan has much more data and thus you do not experience the problem I and many others do.
Photo of David
David, Mobile Master
  • 93,850 Points 50k badge 2x thumb
@Zana, the point of turning on Wi-Fi is to allow any other data transactions to occur while connected to Wi-Fi, rather than over your cellular data. The MMS will be sent through the cellular data.
You could also email the photo instead, while using Wi-Fi.
