Unlimited Incoming Calls add-on
  • Updated 1 year ago
  • (Edited)
I have the $30 plan that includes 100 canada wide calling minutes, that is currently being advertised on the website. If I buy the unlimited incoming calls feature will I be charged long distance when my family calls me from Toronto while I am in Oshawa? My phone number is an Oshawa number starting with 289-657-xxxx
I don't know if this plan is considered a canada wide plan(?).
Photo of Sarah Keith
Sarah Keith
  • 72 Points
Posted 1 year ago
I have unlimited incoming calls add-on and my daughter calls from kitchener to cobourg (me) with no extra charges. I have an older $30 plan with 200 min.
Photo of Allan
Allan, Mobile Master
  • 50,736 Points 50k badge 2x thumb
All pf Koodo's new postpaid plans are Canada Wide. You are correct in saying that you will not incur extra charges with this add on for the call specified.
Photo of Mayumi
Mayumi, Mobile Master
  • 111,356 Points 100k badge 2x thumb
Your Plan $30 for 100 anytime minutes and 100 MB + $10 unlimited incoming calls add-on = $40/mo
They have $40 plan for Unlimited Canada-wide anytime minutes, no data( $5/100 MB Pay-per-use data)
Or $40 plan for 500 Canada-wide anytime minutes and 500 MB
I don't know how much phone call you usually receive, but receiving phone call doesn't cost you long distance charge.  Also, if you make/receive calls during unlimited eves and weekends, it doesn't use your minutes.
I just wanted mention you you have some options/choice depends on your needs :)
I receive more than I make. I keep the 200 min for my calling needs
