Unlimited incoming call
  • Updated 2 years ago
Just want to ask if Koodo has removed the "unlimited incoming call" for all their plans? since its no longer on the description, if so, they should put in details in all plans that all incoming call will be taken off in the included minutes between 8am-6pm (nights are free and weekends) and extra charges applies.
Photo of Jason Lim
Jason Lim
Posted 2 years ago
Photo of Dennis
Dennis, Mobile Master
  • 178,190 Points 100k badge 2x thumb
Nothing should change from existing plans.
For new plans, they are as stated and only include what they say is included.  They would not state what is not included because that would be infinite.
Photo of Jason Yu
Jason Yu
I understand that, since the unlimited incoming call is or was a featured included in all their plans ( call&text, canafa wide) , now they changed it unless you subscribed with unlimited minutes. But they should have put it for FYI to future subscribers and current subscribers planning to update their plans.
Photo of Jason Yu
Jason Yu
That's what in saying, before its available in almost all their plan ( all their plan is canada wide ) but currently its only available with the unlimited minutes plan. Or add $10 add on ..Thats why im asking, also i have the 400 min with unli incoming call.
Photo of Mathieu
Mathieu, Mobile Master
  • 60,768 Points 50k badge 2x thumb
@Mayumi, wow. How many years old is that?? :P
Photo of Mayumi
Mayumi, Mobile Master
  • 109,364 Points 100k badge 2x thumb
I just found it from old Koodo bag :)
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 136,122 Points 100k badge 2x thumb
Having previously worked for koodo, I can confirm that unlimited incoming calls was never included in all, or even on a majority of plans. Going back to when the plans only included minutes and texting, the highest plan was typically for unlimited minutes, while the next highest plan had limited minutes but unlimited incoming calls. On all other plans you were charged for both incoming and outgoing calls. In every case, unless a plan specifically stated that it included unlimited incoming, it did not. That feature was never a default.
Photo of Jason Yu
Jason Yu
Youre right, but it was included in almost all their Plan except for Plan 20 or 25 but from Plan 30 or 35 and up most of my friends are still under this Plan which has "unli incoming calls"but currently its now removed, unless you get the Unlimited minutes plan or add $10 add on for unli incoming call.
