Unfair Data Charge - Can't Control it
  • Updated 7 months ago
Hello,
I have an LG Nexus 5. Unfortunately, when you first setup Android for the first time, data automatically turns on for the setup process. There is no way to bypass this until you skip through the setup process to turn off data.
My plan does not have data, so the 6mb that were used during the setup process was charged to my account.
Is there anyway to dispute this? It seems unfair from my perspective as I did not intend to use data, it the default when first setting up Android.
Photo of sammmmmm
sammmmmm
  • 262 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,580 Points 100k badge 2x thumb
When you first set it up your asked to connect to a wifi before it does anything, connect to a wifi signal and you won't use any of your cellular data.
Photo of sammmmmm
sammmmmm
Yes, I know it asked me to connect to wifi during the setup process, but LTE was already on BEFORE that screen.
Photo of Goran
Goran, Mobile Master
  • 90,880 Points 50k badge 2x thumb
There is th data use grace period as Bob said below so you don't need to worry about the minor data usage.
Photo of Goran
Basically because you have the option to connect to wi-fi during setup, it's very unlikely that you will be able to dispute it. You could always call 611 anf try I suppose.
Photo of BobTheElectrician
BobTheElectrician
  • 62,094 Points 50k badge 2x thumb
There is a 10-day grace period if you are a brand new customer because the providers know you have no idea how much data you will use.
Other than that....
http://community.koodomobile.com/koodo/topics/data-and-how-to-make-the-most-of-it
Photo of Goran
D'oh!
Photo of Mayumi
Mayumi, Mobile Master
  • 112,838 Points 100k badge 2x thumb
Also, even if you are existing customer and you upgrade your phone from Koodo, there is good chance they will wave this "set up data leakage fee".
I got this situation twice before. One was setting up by store rep and one was setting up by myself at home. And it was under 10 MB.
As OP said data was already enabled and there is no way to turned off until you get to set up WIFI.  You should call Koodo and explain your situation (if you are existing customer and this happened)
If you are new customer, then it what Bob said.
Photo of Goran
Good point on if you're a pre-existing customer.
Photo of Jenny Chow
Jenny Chow
  • 90 Points 75 badge 2x thumb
I changed to a new phone and during set up time, I used 96mg data.  can Koodo forgiven this. It occured on the day I change phone & switch plan. I was a Koodo customer already.
Photo of Allan
Allan, Mobile Master
  • 56,906 Points 50k badge 2x thumb
You can try contacting Koodo directly but there is definitely no guarantee anything can be done.
Photo of Mayumi
@Jenny
Did you set it up at a store(where) or at your home?
What phone did you get?
We can't look into your account here in community, so send them message through this link.
You can dispute your charge. I did it  when I got data charge for set up( but, it was only under 10 MB )
https://www.facebook.com/Koodo
Photo of Jenny Chow
Jenny Chow
Thank you. I'll try to send a message via that link. Hope it helps.
I was trying to set up both at the store and at home because it was getting late.
I changed from a Samsung Prime to an iphone 7+, and changed my plan with data to a new plan 'All talk/no data'.
