Undo Lock screen with PIN
  • Updated 2 years ago
I set my new S5 to a pin for lock screen but I want to change it but can't seem to find out how to do that.
Photo of Donna Collins
Donna Collins
Posted 2 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 193,190 Points 100k badge 2x thumb
Go into the phones settings menu and look for the lockscreen & security setting and click on it.
Then right at the top you should see lock screen type, click on that and there you will be able to change your lock type for your lockscreen.
Photo of Daniel Kim
Daniel Kim, Mobile Master
Hi Donna, go to apps>settings>lock screen> screen lock>enter your pin>continue> touch none. This should undo the lock screen. Hope that helps! Also I thought I'd mention that the s5 has a fingerprint scanner. :)
Photo of Melissa
Melissa, Employee
  • 11,708 Points 10k badge 2x thumb
Donna, were you able to change your PIN?  Let us know :)
