unalble to receive and make calls from my koodo mobile
  • Updated 9 months ago
Hi there, I am a 3 month old customer of koodo....i am unable to login in my account for online access.... since 2 days all of a sudden i am unable to receive and make calls from my koodo mobile.....please help
Photo of Riddhi Thakre
Riddhi Thakre
Posted 9 months ago
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Hello Riddhi,
Have you tried removing the sim and a power restart?
Riddhi Thakre
Hi...ya I already did that but still the problem is not solved
Riddhi Thakre
I also don't have that pin number because I was not able to login to my account also....and to solve my problem, rep are asking for the pin number
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
You shoyld have picked your PIN number when you created your prepaid account.
If you forgot it, then rep will ask you a lot of question to make sure you are the one own the account and help you to reset your PIN.
Does your base plan includes talk minutes? Or do you have a Talk booster?
Riddhi Thakre
we have talk minutes in our base plan.
Photo of Mayumi
Did you top up/renew your base plan?
Can you send or receive texts?
Riddhi Thakre
ya I did top up for my plan on 3rd Aug...still not able to make and receive calls as well as not receiving messages
Photo of Mayumi
Try removing the SIM and put it back in, then  restart your phone again.
How did you contact Koodo? (You mentioned the rep asked you PIN).
If you have another phone and if it use same size SIM, you can test your SIM on the different phone to see if it work or not.
If you called them from land line or other phone that uses different size SIM, then talk to them again to get help.
I'm surprise they didn't help you when you called in at first time.
Riddhi Thakre
thank you mayumi...i will definitely try that...and let you know....
