Tune-In Radio Won't Connect When On LTE/4G but Works on WiFi
  • 2
  • Updated 2 years ago
  • (Edited)
About 2 or 3 weeks ago, Tune-In Radio App can connect and stream no problem. I noticed a few days ago that the app can't stream broadcasts anymore when I'm connected thru LTE/4G. But it works fine when I'm using WiFi at home or at a friends place. I know for a fact that the app can still connect to the web cause I can still search for radio stations but it just can't connect stream the broadcast.
Photo of MasterV
MasterV
  • 170 Points 100 badge 2x thumb
  • frustrated
Posted 2 years ago
  • 2
Make sure the tune in radio app is updated through the Play Store
Photo of MasterV
MasterV
It's running with the most up to date app. I'm a techie so I would have at least tried the most basic troubleshooting. Hence why I ended up with the conclusion that Koodo is either blocking it on their end or there's something going on at their end.
AFAIK koodo doesn't block any thing.. Have you tried another device or contacting tune in support?
Photo of MasterV
MasterV
Nope. Doesn't work on my wife's phone either. She's on Koodo as well. But again, works on Wifi no problem.
Photo of Dennis
Dennis, Mobile Master
  • 190,430 Points 100k badge 2x thumb
Have you checked it the app has a setting to enable use over cellular data?
Have you tried a different carrier's sim in your phone (assuming it's unlocked) to see if it works?
Or alternatively, see if a friend on another carrier can use this app on 3G/LTE?
Photo of MasterV
MasterV
App has no setting to enable / disable use when over cellular data.
Tried on a friend's phone who's on the Roger's network and it works no problem both on wifi and on LTE.
Photo of Ivan
Ivan, Mobile Master
  • 96,582 Points 50k badge 2x thumb
Just tried TuneIn over cellular. Nothing plays.
Photo of rikkster
rikkster, Mobile Master
  • 68,314 Points 50k badge 2x thumb
It could be that you're in an area with intermittent 4G or LTE coverage. I don't normally use the app, downloaded it anyway just to try it out. I'm able to listen to streaming broadcasts over 4G without issue, confirming that nothing is blocked at Koodo's end.
Photo of MasterV
MasterV
Tried at my home and it doesn't work there. Now in the office and still doesn't work. Just tried a speedtest to see and i'm currently sitting at 22.06mbps down and 1.06mbps up. Not the fastest but it still shouldn't prevent me from streaming.
Photo of rikkster
  • 68,186 Points 50k badge 2x thumb
Which Android phone do you have?
Photo of MasterV
MasterV
Galaxy S6
Photo of rikkster
One other option is to get into recovery mode, wipe the cache partition and see if this method yields any results. There may be some residual files conflicting with the operation of TuneIn.
Photo of MasterV
MasterV
Resetting cache partition didn't work.
Photo of rikkster
Not sure what else to add short of trying a factory reset. I think the app is somehow problematic, though it does seem a little odd that it's affecting two phones simultaneously.
I can't explain why it's working perfectly on my BB Priv and why it refuses to work on your Galaxy S6. I noticed that the app received an update five days ago. Perhaps the update may have something to do with why TuneIn is not working correctly. If you find a solution, keep us posted.
Photo of MasterV
MasterV
Thanks for the assistance. Will try and contact them (Tunein)  instead for support. But there is a possibility that I'll just be passed back to my service provider and ask them. We'll see.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,312 Points 100k badge 2x thumb
Working perfectly fine over cellular data on the Pro version which is what I have, is it possible your using the free app and it's a limitation of the free app that it only works over wifi.
Photo of MasterV
MasterV
Have the pro version as well. Not sure why it just stopped working. Have contacted their support to see if they can further troubleshoot.
Yeah I was using it perfectly fine even on my Galaxy S6 & my S6 Edge just a few weeks ago so maybe it was a recent update to tune in that broke it on that device, have you checked the playstore comments to see if any other ppl are complaining using the S6 (ie same device in the comment section)
Your not rooted are you?
Photo of MasterV
MasterV
Ok. Tested tunein on my old phone with same sim card I'm using on my current S6. And it worked fine on my S5. So the problem lies with their app on S6.
Thanks for all the assistance.
