trying to text internationally but they are not receiving what could the problem be??
  • Updated 2 years ago
I am trying to send a text from Canada to Australia but they keep saying in Australia they are not receiving the message. What could the problem me???
Photo of Melissa A Shoup
Melissa A Shoup
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
It could be lots of reasons, Melissa... but first things comes to mind is did you add the prefix +1 and the country code to the number?
Photo of Goran
Goran, Mobile Master
  • 90,564 Points 50k badge 2x thumb
The number you got might have a 0 in the leading area/provider code. Make sure you do +61 and the number without a zero after the 61 country code for Australia. Then they should receive it. For example if it's 04-1234-5678 you need to do +61 and then 4-1234-5678 like +61412245678
Photo of Daniel
Daniel, Employee
  • 5,702 Points 5k badge 2x thumb
Hi Melissa! Were you able to text to Australia in the end? Keep us posted :)
Photo of BobTheElectrician
BobTheElectrician
  • 61,868 Points 50k badge 2x thumb
http://www.howtocallabroad.com
That will also give the correct procedure for them to answer you in case that needs clarification.
Photo of kerstin.lunenburg
kerstin.lunenburg
  • 162 Points 100 badge 2x thumb
I have the same problem....I never changed my plan and have this one now for more two years. Since a few days my parents (living in Germany) don't receive my txt messages anymore. I didn't make any changes to my phone. The right cell phone number from my parents is saved.
A few from my friends also don't receive my txt msg like they usually did.  What could be wrong?
kerstin.lunenburg
Anybody???
BobTheElectrician
Try a different texting app. If it then works, it's probably a cache problem with your current app. Deleting and reinstalling the app may work, but you will lose any texts you have on your phone currently.
kerstin.lunenburg
Thank you. I guess I need to call "Technical Support". Just came to my mind that I did allow to run an update. Never updated it before yet, so this seems to be the issue.
