Trying to figure out if I am being forced to change my base plan because of my balance? !?
  • Updated 3 months ago
So my base plan is the $45 plan I have a 55$bal in my account right now,can $45 not go towards my base plan and I buy a talk top up with the remainder?is it really forcing me to change my base place to a $55 plan and now am i really going to have to buy another top up card?
Photo of sandie
sandie
  • 80 Points 75 badge 2x thumb
  • frustrated
Posted 3 months ago
Photo of David
David, Mobile Master
  • 93,388 Points 50k badge 2x thumb
No, you should be easily able to top up.with any plan you choose. The norm is to top up with the plan you did the month previous.
Photo of sandie
sandie
For some reason it's not letting me ...I added a 50$ top up card ..I already had a 5$ bal ..so that should take care of my 45$ base plan ...it says I have a 55$ bal ...for some reason it's not applying it to my base plan ...it has every month before...guess I'll have to call tomorrow arghh..thanks anyways for the help ..appreciate it!
Photo of rikkster
rikkster, Mobile Master
  • 68,228 Points 50k badge 2x thumb
Stick with your current $45 baseplan. After business hours and on some weekends, the system takes a little longer to process manual payment. The system will 'see' the amount required for your baseplan and should apply the funds later this morning between the hours of 6 and 9 am, or earlier. When payment goes through, you should see a $10 balance which you can put toward a talk top up.
Photo of Mayumi
Mayumi, Mobile Master
  • 114,740 Points 100k badge 2x thumb
So, your plan is $45 and you have $55 on your account balance plus you want to buy a $10 talk booster.
Why don't you buy a booster now if you needed/wanted since it won't expier as long as you renew your booster.
And you still have $45 to renew your base plan.
