Trouble With MMS on Nexus 4 Android 4.3
I am having trouble with sending pictures over MMS. So, in my APN settings, I have two proxies, one for something and one for MMS. If I leave both proxies intact, MMS works, but my internet browsing does not. If I remove the first proxy, browsing works, but MMS does not.
Am I doing something wrong?
P.S. I have tried with data always on, and WiFi either enabled or disabled.
Thanks for the help!
Mayur
Photo of mayur.saxena1997
mayur.saxena1997
  • 90 Points 75 badge 2x thumb
  • puzzled
Photo of John Burke
John Burke, Mobile Master
Try this:
Go to the APN list, tap the 3 dots in the upper right corner & select "Reset to Default"
mayur.saxena1997
Alright, so I tried this, and it brings back PC Mobile and Telus, and I am unable to use data. Is there something else I have to do, such as in APN type?
Photo of John Burke
You should delete those 2 and then manually add the Koodo APN--> http://koodomobile.com/en/on/switch2k...
mayur.saxena1997
OK, so now MMS works, but certain data features don't work, such as using the Play Store, or Speedtest.net. However, they do work if I remove the first proxy, not the MMS proxy.
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi there, are you still experiencing issues with MMS? If you are, give us a call so we can have a look into it. We can be reached at 1-866-995-6636 from a landline, option #6. Thank you!
________________________
