tried dialing, get message "not registered on network" help
  • Updated 2 years ago
Photo of Gay MacQuarrie
Gay MacQuarrie
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 107,634 Points 100k badge 2x thumb
Hello MacQuarrie.
Do you have any service? Can you at least text?
Gay MacQuarrie
can't text - think it is the sim card
Photo of rikkster
rikkster, Mobile Master
  • 68,420 Points 50k badge 2x thumb
Try Settings > More > Cellular networks > Network operators - the path to get to this setting may differ slightly on your device. Manually scan for available networks, when Koodo appears, tap to select it and a message should appear, 'Registered on network'. If that doesn't work, there may be a problem with your SIM card.
Gay MacQuarrie
believe it is the sim card
Photo of rikkster
Let us know if the new SIM card fixes the issue.
Photo of Tayeb A
Tayeb A, Employee
  • 18,208 Points 10k badge 2x thumb
Hey there,
Have you tried to insert your SIM in another phone to see if it works? If it works, you can insert it again and make sure it's clean and that it's aligned on the SIM Tray. However, if it doesn't work, Rikkster's probably right, it might be necessary to change it, if you've had the same SIM card for a long time.
Let us know if you still need help!
Gay MacQuarrie
thanks, believe it is the sim card - have had it for a long time.
