Travel to Mexico and Roaming Charges
  • 3
  • Updated 10 months ago
I am travelling to Mexico and would like to be able to send and receive texts and check email while away. What are my best options? Do the add on plans cover all the additional charges when my phone is turned on? I don't want to be surprised by a large bill.
Photo of Tammy Goulding
Tammy Goulding
  • 112 Points 100 badge 2x thumb
Posted 3 years ago
  • 3
You need to decide what you want while you're in Mexico.
Do you care if you have data or not? If you do, make sure you choose a roaming add on with data. Even with the add in, if you exceed the allotment there will be overage charges.
If you don't then just take a talk and text add on and turn mobile data off on your device.
Wifi is always free and can usually be found easily enough.
Photo of Daniel
Daniel, Employee
  • 5,714 Points 5k badge 2x thumb
Hi Tammy!
As a suggestion, when in Mexico, you could take the $40 International roaming add-on that gives you 50 outgoing texts, unlimited incoming texts, 50 MB of data and 50 minutes of talk time.
Here are the pay-per-use rates: $0.60 per outgoing text; incoming text are unlimited; $5/MB and $1.50/a minute.
For more details, click here: http://koo.do/trvllng
Hope that helps and happy travels :)
Tammy Goulding
Thank you for the info. Will I only use this extra data while I am out of the country, I assume my normal data will be the used while still in Canada. Is this correct?
Correctomundo
Photo of kim gueldenhaar
kim gueldenhaar
  • 60 Points
Watch out in Mexico for me I would buy a paygo SIM card there I have heard of ten thousand and more dollars charges if you use your phone in Mexico
Photo of Allan
Allan, Mobile Master
  • 62,876 Points 50k badge 2x thumb
This thread is 2 years old. As per the crazy overage charges youve heard of, phone companies need to block your data usage after $100 so unless your making lots of calls or consent to use more data ot shouldnt get into the thousands.
Photo of B.
B.
  • 60 Points
Allan, since your post is the most recent, can u please advise what you would suggest for using Koodo in Mexico?  We are going for 5 months. tks.
Photo of Russell S
Russell S
  • 274 Points 250 badge 2x thumb
I have been told recently from a Koodo rep that Koodo will be offering a "roam like home" option in the next couple weeks. I am unsure of the cost, but if its like Telus, I would expect to pay $10 per day. This would enable you to use your cell phone like home, but without any unexpected charges
