Travel to China for two weeks.
  • Updated 2 years ago
My husband and I both have a Koodo account and we are going to china for a couple of weeks this month. What will be the best way to change the current service so that we can use our phone in China without breaking an arm and leg? Thanks!
Photo of Violinit
Violinit
  • 104 Points 100 badge 2x thumb
Posted 2 years ago
Photo of CH Sajid
CH Sajid
  • 276 Points 250 badge 2x thumb
The best way you change your plan to minm $10 /month and change it on your cut off date otherwise Koodo charge you extra and tell them in advance once you come back from china after a month or weeks you want to use same plan you are using now
I make a change last Dec when I visit Hong Kong they put extra charge and they didn't explain me about the plan
Now change to Fido the best service provider
Photo of Violinit
Violinit
Good to know. Thanks so much!
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi Violinit,
If you want to use your phone in China, you may want to add one of the international roaming packages Koodo offers. These packages will include outgoing texts and certain ones include calling and data as well. If you use your phone without an add-on, you will be charged the following:
Minutes: 2.50 per minute
Texts: 0.60 per outgoing texts
Data: 10$ per megabyte.
If you plan on using the phone a lot, you may consider getting the phone unlocked and getting a pre-paid carrier in China to use while your there. Should you decide to get an add-on, make sure that you add it before arriving in China. They all last 30 days, so you do have a good buffer if you add it a day or two before leaving for China.
Let me know if you have any other questions!
Photo of Violinit
Violinit
Thanks Mathieu! This is very helpful! Is there a couple discount for international roaming or unlocking?
Photo of Mathieu
No problem at all!
There is no couple discounts. Unlocking through Koodo costs 35$ per phone, so 70$ for both of your phones. Same thing for the international roaming, you would pay for it for each line you want to activate it on.
Photo of Violinit
Violinit
One more question Mathieu, once Koodo unlocked the phone, does it keep unlocking? We are also going to Europe this fall and I wonder if we have to pay for the second unlocking by then. Thanks for your help!
Photo of Mathieu
Nope, once the phone is unlocked, it's unlocked!
