Travel Plan Question
  • 2
With the travel plan for Mexico/the Caribbean, does it cover calls/texts to Canada, or just calls/texts within whatever country you're in?
Photo of Rebecca Franklin
Rebecca Franklin
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
  • 2
Photo of Robert
Robert, Mobile Master
  • 103,644 Points 100k badge 2x thumb
Yes it does. You can text from US to > Canada. This is what the add-on is for!
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
You'll make El Tabador upset, Robert, Mexico is not the US ;)
Rebecca Franklin
What about Mexico > Canada? or within Mexico?
And thanks!
Photo of Yannick
Yannick
Hi Rebecca, the add-on will cover calls/texts from Mexico to Canada as well :) Enjoy your trip!
________________________
