Travel plan data setting on samsung
  • Updated 2 years ago
  • (Edited)
I have the 10ALL plan while traveling but the data feature isn't working. Is there a setting I need to enable or disable on my Samsung neo?
Photo of dianne
dianne
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 67,538 Points 50k badge 2x thumb
Check your preferences to see if Mobile Data and Data Roaming are enabled.
Check with www.willmyphonework.net to see if your model of phone is compatible with your temporary local carrier.
If there's a data block on your account, you will need to contact Koodo. Send them a private message on Facebook or Twitter. Those reps have access to your account details that we lack here.
Photo of dianne
dianne
This reply was created from a merged topic originally titled Travel plan data setting on samsung.
I have the 10ALL plan while traveling but the data feature isn't working. Is there a ain't I need to enable or disable on my Samsung neo?
Photo of Bernard
Bernard, Official Rep
  • 81,048 Points 50k badge 2x thumb
Dianne, there is no data block on your account and the US add-on seems to be in order. If you can text and call it makes me think that your phone settings need to be adjusted. Data roaming is turned on right?
