Travel and Roaming
  • Updated 7 months ago
3 Questions.
1. Where are all your roaming packages (other than easy roam), I can't find them on your website.
2.  When you hit the easy roam monthly maximum ($100 per billing cycle), what do you get charged then?  How does this work?
3.  24 hours for easy roam? If you activate easy roam (ie make a call) at 5pm, does that mean you only get one charge to 5pm the next day?
Thanks!
Photo of Dan Petryk
Dan Petryk
  • 600 Points 500 badge 2x thumb
Posted 7 months ago
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
1. The other roaming packages are gone and were replaced with easy roam.
2. The charges are capped at $100. Once you reach $100 you no longer get charged for that billing cycle.
3. Yes. 24 hours from when you first make a call, etc.
Photo of Robert
Robert, Mobile Master
  • 103,584 Points 100k badge 2x thumb
Yes it's 100$ per billing cycle, so theoretically she could get charged up to 200$ if she's in between 2 cycles which I find quite annoying.
Her Canadian data overage is $5/250MB (she has shock free) so she will be charged that if she goes over?
Yes she will
She never gets anywhere near her talk limit but if she did it would be the normal Canadian overage rate for minutes?
I'm almost that this is what will apply. You already pay 10$ to us your plan like your would back home. I can't imagine charging more overage charged the back home.
Photo of Dan Petryk
Dan Petryk
OK, she will be in Columbia next month, all during the same billing cycle.  She has a shock free plan.  I expect her to be charged $10/24hours after she takes or makes a call to or from Columbia or Canada, sends a text, or uses data.  Her maximum charge will be $100 plus any data or minutes overages.  If she goes over her data, her Canadian plan will charge her $5/250MB (it's in her agreement from sign up) and if she goes over her minutes she will be charged the same as if she went over in Canada. That about sum it up? Thanks!
Photo of Dennis
Dennis, Mobile Master
  • 187,078 Points 100k badge 2x thumb
Hi Dan.  Yes that is a great summary.
Photo of Roamer
Roamer
Disappointed that the other roaming options have been removed. Its now much more expensive to roam if you just want to text.
Photo of Allan
Look into local sim options.
In the US you can get unlimited text plans for $3/day or $25/month. (Those are just a couple I remember).
