transformers and data issues!!!
my data is on, but it says there is no connection, it also makes a weird sound during calls like the transformers are coming into my phone lol...what can I do? its a nexus4
Photo of Jennifer Hicks
Jennifer Hicks
Photo of John Burke
John Burke, Mobile Master
"chik-chak-chek-chok-chuk"
In regards to the Data issue, have you tried resetting the APN to default?
Settings--> Wireless & networks (More)--> Mobile network settings--> Access Point Names--> tap the overflow button (3 dots)--> Reset to default
Also within the "Mobile network settings" section, ensure "Data enabled" has a checkmark next to it.
Then reboot your phone.
Photo of Dennis
Dennis, Mobile Master
  • 196,004 Points 100k badge 2x thumb
Lord Megatron? Is that you?
:p
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,220 Points 100k badge 2x thumb
As far as the sound your hearing is it about every minute or so or is it continuous? If it's every minute or so you might have a minute minder on that let's you know when a minute of your usage is gone by. You can turn it off in the dialer app settings I believe. Just go into the dialer app and hit the menu button (3 dots) and select settings from there and uncheck if there is an option for minute minder. If it's on the phone during the entire call is it while your using the phone or a Bluetooth piece to talk through?
