Trail camera with mms capability
  • Updated 1 year ago
Recently bought a trail camera with mms capabilities. Also purchased a prepaid sim card, activated it and searched the faq's an the community for Apn settings to program the settings into my camera. however it seems that the camera cannot connect to the mobile network. I've searched youtbe also, on the proper setup, they all seem to work but I live in  different country than all these videos so the settings are different.
Photo of Leon Dubitz
Leon Dubitz
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 97,688 Points 50k badge 2x thumb
Did you also check for compatible frequencies? A lot of these types of radio equipped devices tend not to be compatible with Canadian networks.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,898 Points 100k badge 2x thumb
Here's another thread that's talking about what you possibly have and that it may only work with Telus for some reason. https://community.koodomobile.com/koo...
Leon Dubitz
the automatic apn settings on the camera list telus in canada, however there is a manual apn setting also. Here you can set all of the apn inofrmation manually and as per the provider.
Leon Dubitz
Are Canadian networks not 2G/GSM compatible?
These are the frequencies we are currently using at Koodo.
4G LTE and LTE Advanced:
2100 MHz downlink and 1700 MHz uplink (AWS)
1900 MHz
700 MHz
850 MHz
HSPA: 850 MHz and 1900 MHz (UMTS)
CDMA: 850 MHz and 1900 MHz
These are the Koodo APN settings you are using exactly correct?
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Leon Dubitz
so this tells me that my camera is not compatible? Im not a communications tech, so I really have no idea what these frequencies mean.
the information provided for my camera says it is 2G/GSM.
  • 203,666 Points 100k badge 2x thumb
Koodo does not have a 2g network no unfortunately not. I'm not sure if Rogers still has theirs up and running or not but it's old outdated technology so they may have shut theirs down as well.
Photo of David
David, Mobile Master
  • 93,728 Points 50k badge 2x thumb
Rogers operates the only 2G network in Canada.
Photo of Goran
I thought that might be the case. The only carrier in Canada that uses 2G is Rogers / Fido and anyone else that uses their network. Unfortunately you're out of luck unless you get a plan with them. Longer term it's a question of when before 2G networks get shut down as well so keep that in mind for future purchases that only have 2G
Leon Dubitz
DAAAANNNNNGGGG!!!!
ok so now that I have these sim cards .....can i return them for a refund? at least the one i havent activated?
Leon Dubitz
Thanks guys, I appreciate your help.
