Top up my data
How do I top up my data 100mb in the middle of a billing cycle? Can I do it online?
Photo of Maddy Mathews
Maddy Mathews
Photo of John Burke
John Burke, Mobile Master
Are you referring to Pre-Paid or Monthly Add-ons?
Maddy Mathews
Monthly. I have the $30 plan that has 100mb on it, but I am nearing the limit and someone told me you could add on another 100mb for 5 dollars but I can't figure out how to do it with self-serve.
I'd rather add a temporary chunk of data rather than change to a more expensive plan just yet.
Photo of Starfox
Starfox
  • 5,718 Points 5k badge 2x thumb
Unfortunately, whoever told you that was incorrect. There is no add-on for $5/100mb
Maddy Mathews
Oh, bummer.
Thanks anwyay though.
I don't think I have Data Saver, but i'll look into it.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,092 Points 100k badge 2x thumb
The overage rate on the Canada Wide Data 30 plan is $5/100 mb. It automatically applies if you go over your data limit.
Photo of Starfox
Starfox
Based on what you mentioned, you might have this plan... Canada Wide data plan 30
Maddy Mathews
Oh cool, thanks Timo for the info!
Yes that's the plan I have right now I believe.
