Top up problem
  • Updated 7 months ago
I just added 10$ / 100 top up to my account but now its showing that i still need another 5$ ? Why? I'm trying to add minutes not to renew my bsse plan which is still good gor another 28 days
Photo of Khaled Ahmadi
Khaled Ahmadi
  • 102 Points 100 badge 2x thumb
Posted 12 months ago
Photo of Mayumi
Mayumi, Mobile Master
  • 115,202 Points 100k badge 2x thumb
How did you add $10? From "Add Booster add-on"? or from "Top up" Tab?
What is your "Current Balance"?
Photo of Erin Kenny
Erin Kenny
  • 60 Points
I tried to add $55 ($25 for data, $30 for talk) and the damned thing charged me $110!!!
Any idea how to get my money back?
Photo of Mayumi
  • 115,066 Points 100k badge 2x thumb
Did you top up your account balance first?  or you picked up boosters and added funds?
What base plan do you have?
Does it show 2 x $25 for data and 2x $30 for talk now?
Photo of hansoo kim
hansoo kim
  • 60 Points
Hi Erin Have you sold your problem? I have the same thing happened to me.
Photo of Mayumi
Can you start a new post using this link?
https://community.koodomobile.com/koodo/topics/new
We need to know what is " the same thing happened to me".
What is your base plan?  What did you try to add and what message you got...etc?
Khaled Ahmadi
Add booster add on. Balance is 10$
Photo of David
David, Mobile Master
  • 93,696 Points 50k badge 2x thumb
Wondering if you need to top up in excess one the value of your next base plan purchase to be able to buy boosters?  This might be to ensure the continuity of your plan.
Khaled Ahmadi
That wouldn't be right. My base plan is 15$ the 100 mins for 10 bucks is more than enough for my need and I'm not using the phone after august
Photo of Sophia
Sophia, Mobile Master
Yes it's confusing Khaled, but what they mean there is that IF you wanted to top up, $5 is needed (in additional to the $10 you already topped up).
You can safely ignore that and use the funds to get your booster.
After that it will say that $15 is needed on Aug 19, but if you have no plans to keep prepaid, you can ignore that and just let it expire then.
Khaled Ahmadi
Thank you
Khaled Ahmadi
Photo of Mayumi
I have an  auto top up and my base plan is $15. I have $3 balance on my account and Amount due says $12.  It's saying that for renew your base plan.
But, if I go  "Add Booster add-on" > Pick a booster : $10 talk..., then pop up window ask me to add $7.  So, I guess you can ignore Amount due on "Overview" page.
BTW, You currently has 13 min + 100 min on your account.  Do you need add more minutes at this time? Especially you mentioned -  100 mins for 10 bucks is more than enough for my need and I'm not using the phone after august.
Khaled Ahmadi
Thanks.
