top-up / pin number
  • Updated 1 year ago
I bought a top-up credit in a Koodo shop, the assistant was supposed to activate it, but it still shows that the balance is 0. The phone doesn ́t work and I don ́t seem to be able to use the same PIN number again.
Photo of Renata Peskova
Renata Peskova
  • 90 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
Have you tried applying the card to your account yourself? Double check that you are inputting the right characters.
Photo of Robert
Robert, Mobile Master
  • 103,644 Points 100k badge 2x thumb
I think she tried but didn't work. I'd suggest to call the store where you bought it ...
