Top up my prepaid phone
  • Updated 7 months ago
Usually use my computer to top up I will be doing it from my cell phone calling 611 do I have to have my password handy
Photo of Tracey
Tracey
  • 400 Points 250 badge 2x thumb
Posted 7 months ago
Photo of rikkster
rikkster, Mobile Master
  • 68,304 Points 50k badge 2x thumb
Hello Tracey,
The system will ask you to enter a four-digit security pin number. If you've forgotten the pin number, wait to speak to a representative. They should be able to help you create a new security pin. There is no charge for this.
Photo of Tracey
Tracey
Thank you is there a way to change my security pin in the prepaid self serve ? I saw to change password and security question but don't see the security pin
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
I don't think you can change your security pin through self serve.
(You need to speak to them )
Photo of Tracey
Tracey
Ok thanks I'll have to call then
