The base phone connected to the Koodo hub works fine, however none of the handsets that go with the base phone are working. What can I do?
  • Updated 11 months ago
I have connected my base phone to the Koodo hub and it works fine, however nine of the handsets will work. What can I do?
Photo of Patty Carter
Patty Carter
Posted 11 months ago
Photo of Allan
Allan, Mobile Master
  • 57,086 Points 50k badge 2x thumb
Are you using wireless phones that come in a bundle in which 1 phone has a base in which the others wirelessly connect to?
Something like this:
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Basic question but have to ask, are the other units bases plugged in to AC power?
Patty Carter
Yes, the handsets are plugged into a regular plug in.
Patty Carter
Yes, AT&T brand.
Photo of Allan
When you press the talk buttons on the other handsets do you get a dial tone?
Patty Carter
Ok, I think I know he problem. Two handsets must go with my downstairs phone, which is another base unit. Can't believe I didn't realize that one!!! So I assume that if I disconnect the downstairs base phone and handsets, I will be ok. Missing a few phones, but ok. You can tell I'm a little challenged with these type of things. Beyond my ability to run a wire from downstairs to the hub upstairs, LOL. Thank you so much.
Photo of David
David, Mobile Master
  • 89,450 Points 50k badge 2x thumb
You can plug both base units into the hub.
You can also use the existing wiring in your house IF, and only IF, the house telephone wiring is disconnected from the Telco wiring where it enters your house.
Patty Carter
Thank you. I now have both bases plugged into the hub and all handsets are working. Have a great day!
