Thailand calling problem
  • 2
Need help I am trying to call a number in Thailand to a cell phone .. Chaing Rai is the city I dial 011 66 then the number but can not get the person . I have double check cell number but call not going through help me
Photo of Jon Moore
Jon Moore
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
  • 2
Photo of Ahmad
Ahmad
You need to make sure that these two add-on's are on your account/line:
-Pay Per Use Intl Long Distance ($0)
-International Voice Roaming ($0)
Without these add-ons, you won't be able to roam overseas. You can add them on self-serve: https://www.koodomobile.com/sso/UI/Lo...
Photo of BobTheElectrician
BobTheElectrician
  • 67,622 Points 50k badge 2x thumb
Ahmad's answer is fine, as far as it goes.
Please let's not confuse roaming with long distance any more than it has been in the past.
Intl long distance: lets you call from Canada to many exotic places. By default it's off so your 3-year-old doesn't hit a 1-900 number in Hong Kong while playing with your phone. A wise protection for everybody, but has nothing to so with ...
Intl roaming: also off by default. You won't even connect to a local network. Lets you receive & make calls from just about anywhere in the world provided you are not in Canada. Junior needs this add-on so that he can now push the flashy buttons returning his call and connect from there.
Photo of David
David, Mobile Master
  • 93,820 Points 50k badge 2x thumb
I would try calling from a landline to see if the issue is the carrier (Koodo) or the recipient's phone.
