texts not working with Data on
I am unable to send texts when my data is turned on - what am I doing wrong??
Photo of Andre
Andre
  • 220 Points 100 badge 2x thumb
Photo of Issa Barmawi
Issa Barmawi
  • 1,330 Points 1k badge 2x thumb
what is your device?
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
I guess you have a samsung galaxy ace... this is a known issue with the device, you will have to turn off your data or be connected to wifi for your messages not to fail...
I will recommend you to download the widget Data Enabler, you install it on the home screen and this will save you time by disabling/enabling the data only by tapping on an icon...
Hope this helps...
Photo of Iglooman
Iglooman
  • 4,090 Points 4k badge 2x thumb
Also, if you have the Galaxy Ace and you have issues with sending/receiving texts, make sure you have at least 20MB free internal memory. If I install too many apps and run less than that, I'll start getting weird errors about not being able to receive texts.
Photo of Andre
Andre
Yes we do have the Galaxy Ace. Never thought to look into that before getting it. That's not cool!
I will look into the widget you mentioned - hopefully I can figure that out! Wish there was another way around it!
Thanks
Photo of Iglooman
Iglooman
If you just got your Galaxy Ace you should be able to bring it back and trade up to a newer phone. I'd highly recommend it as you'll be fighting for memory with the original Ace. Go for the S2X and you'll have a much nicer experience (as someone who's been able to play with a friend's S2X and fights with his own Galaxy Ace... :)
